Donny,
What model do you have? The later cars had radiators painted a gloss black and then the fan guard was brush painted red.
Don't be afraid of this project, but take the opportunity to do the most work you can on all the components you will be removing and even some that are near by.
If the radiator has not been flushed out recently, this is a good time to flush the entire cooling system and then have the radiator boiled out in a hot tank and checked for leaks. If the core is getting punky, now is a good time to have it recored.
Is the thermostat the right one for your area? This is a good time to replace that, and of course, a new gasket. Check the thermostat housing studs and make sure they are in good shape and can be reused. I put a little anti seize on the threads before I reinstall the nuts becuase I really don't want those little studs to break off in the future.
Is your fan belt up to snuff? since it is coming off with the pump, now would be a good time for a new one.
Does your car run cool enough in the summer time? If you were thinking of trying the Texas Cooler fan, why not buy it now so you don't have to remove the radiator again in the future.
Is the front of your engine compartment clean? With all these parts removed, now is the time to spray on some engine cleaner and really get into the nooks and crannies that are impossible to reach when everything is together.
I have to admit that I turn relatively simple projects into big deals, but my goal is to try and go into these areas once and get everything done at one time. I'd rather spend three days doing a one day job that going back in three or four times.
