when I flushed out all the old coolant from the radiator /block I left it dry while I waited for my new elbow joint to come in the mail. It didn't dawn on me that the seals would dry out. Apeearently they did because now it leaks. I think it's the mechanicle seal on the pump. I bought some leak seal that says it olso conditions seals but can't try it out untill I get new flex lines for the brakes so I can drive the car aroun right after adding the the leak seal. Do you think the leak seal will do the trick? Or should I bite the bullet and order a new water pump while I'm ordering the brake lines anyways? I'd rather not get the pump(because I can't really afford it right now) if there's a good chance of the sealant working but I'd really hate to find out it doesn't work and be off the road that much longer because I went the cheap rout by not ordering it.
