Nelson
This afternoon I filled my radiator as one of the final steps in resurrecting Sprite engine. Shortly after I started pouring into the radiator I heard splashing under the car. When I turned the handle on the block drain spigot the stream of fluid stopped. Feeling smug with myself I finished filling the radiator to the top. Everything seemed fine. Tonight I did a garage check and saw a stream of wetness running away from under the car. After a bunch of paper towels and a wet back it appears that the source of the leak is my water pump. Do I need to order from one of the usual parts suppliers or is there a chance that a place like NAPA or Autozone might carry a replacement to use on my 948? If I have to order from afar I won't reach my goal of starting the engine this week.
