... No ones luck is that bad?
layful: Dale
Nope ... mine is worse. Some might recall my miserable saga with a WP on a long road trip in 2014. In short:
1) Installed WP rebuilt by a real craftsman when replacing seal on timing cover
2) WP failed catastrophically after about 2K miles in Green River, WY (coolant gushing from pump)
3) Got motel room, had new WP overnighted from Moss
4) Change out pump in motel parking lot
5) Start engine, WP shaft breaks immediately and fan damages radiator
6) Overnight new WP and radiator ($900) from Moss, with special instructions to CHECK THE PUMP BEFORE SHIPPING FOR WEAK SHAFT (as indicated by side play in shaft)
7) WP arrives in Green River with BROKEN SHAFT
8) Trailer car home to CA
9) Return rebuilt pump to rebuilder, who determines rubber bellows on pump seal split, releasing copious amounts of green liquid
To Moss's credit, they made me (somewhat) whole but annual trip was cut short (first time in 20 years didn't complete trip)
Anyway, AFAIK the only WPs available are the notorious County brand; confirmed with Moss tech specialist that County has known quality issues. Original rebuilder--who was mortified but not at fault--sent another rebuilt pump at no charge to me, which I installed. Rebuilder also found original BJ8 pump on the shelf of a long-time rebuilder; I bought it and threw it in the boot. Also have an older County pump; produced before County began to have quality issues (it's telling to me that this pump has some numbers stamped on the shaft which the two failures did not). The pump I replaced when I did the timing cover seal was a County with over 60K miles on it but it appeared that something was starting to deteriorate inside the pump housing (rebuilder did an autopsy on the County pump as well--the seal was, well, funky).
The lesson: Good luck finding a 'new' pump of quality. I now have two pumps rebuilt with original housings; you'll notice the 'new' ones don't have the boss for the grease hole (or, if they do, it's not tapped for the fitting).
