RJS
Hi
Any tips for replacing a water pump? I am about to dive into this project. My water pump was replaced by PO when engine was rebuilt in 1998. I am mostly interested in how to remove the pulley.
Do I remove the water pump first, then the pulley? Or remove the pulley first? The water pump is held on with one bolt and two studs with nuts. Either way, stud or bolt, I can't see that there is enough clearance to remove them without removing the pulley first.
Then, when installing the water pump, any tips for installing the pulley? I don't want to damage the new bearings or seals by forcing the pulley on.
Thanks
Thanks
