Got_All_4
Installed one of those up rated water pumps from Moss when I installed the engine. In the past i remember reading posts where there were problems with the pumps. Horror stories where pulleys were coming off and going through the radiator. Herd some strange noises under the bonnet tonight and was watching the engine run and noticed a pretty good wiggle in the water pump pulley. You can actually grab it and wiggle it and I din't notice the shaft moving ether. So the pulley must be loose on the shaft. Tried tightening the nut and it's tight. The pulley is the original that came with the car so are they compatible?. What could be going on?
