Thanks Andy and John for your positive words. I have not started the vehicle back up out distress. Yes John, I understand that stop leak in some form is put in on the assembly of aluminum engines, and that some of those early orange colored antifreezes were designed to stop leaking on V6s by GM. Stop leak is something I advise others not use. I would say by a new radiator or heater or fix the leak. Stop leak seems like it is for a stop gap measure on a half dead car. This is an Engine I have many hours into and much money and putting the leak product in was agonizing. If it does work, I would not trust the vehicle for a long trip. My theory is one of culminating ideas. I think the head gasket was too thin, the engine block surface was too flawed, so that the sleeves on the lifter side of the block coupled with a thinner gasket allowed the compression chambers to seal, but did not permit the matting of the head and block next to them. I would not be surprised to find the water in the head slowly bled down just sitting. Pulling the head and finding a good quality gasket is what I should have been done, but I opted for the easy way out because the old radiator and heater might benefit if the product does work as they maintain, and plus it could be a crack, I do not know. However, when I got that gasket kit, I did not like the quality and used it any. The valve cover gasket was so thin; it would not seal and I bought another from a local shop that still works on old English stuff. so go figure.
steve
