So what am I looking at here? Where do I need to start? Is it a head gasket? A water pump? Where do I start first? /ubbthreads/images/graemlins/confused.gif
Is the entire oil pan full of milky stuff? Or, do you just see it around the filler cap on the rocker cover? If the pan is full of milky stuff, you (obviously) have problems. If it is just around the filler area, it may simply be condensation from sitting.
Milky oil not good, do not run. If it is indeed milky prob from the head gasket. Lots of other things places it could come from but that or water pump is most obvious.
