Water drain plug size?
Crisis
Could anyone out there tell me the correct size of the water drain plug on the TR6 block (right side, directly over starter). Mine has some bizzare plumbing which entails a hose coming from this drain and then 't'ing into the front manifold hose behind the thermostat housing. I want to do away with all that. I know there may be a reason why it was done that way, but I want to try it anyway. It may have something to do with the fact that when I got the car it had neither the rad shroud or a thermostat. Thanks.
