Spitfire Watchpoint - spitfire wheel cylinders
eschneider
Ran into trouble when replacing wheel cylinders on a '67 MKIII spitfire.
1) As shown in the photo below, the fully collapsed dimension on the cylinders is roughly 45mm. When the drums wouldn't fit over the brake shoes, I discovered that the compressed dimenion of the old cylinders was roughly 42mm. In order to resolve the issue, I had to grind down (very slighly) the contact pads on the brake shoes.
2) after the brakes were assembled and bled, and after a test drive and overnight sit - the next morning there was some seepage around the bleeders. Two attempts to re-seat them failed; I had to replace the bleeders with the old ones to stop the seepage.
The wheel cylinders used were AP / Caparo. Perhaps I got a "bad set", or maybe I missed something - but the experience is worth sharing in case someone else has this problem.
Were your old rear wheel cylinders too rough to rebuild?
Scott
They were probably rebuildable, but on small bore cylinders rebuilding is always a gamble. If I had it to do over again, I'd have the original ones sleeved.
My experience has been the same as yours Andy with cars that were running and which had not sat for years and years. It will be interesting to see what kind of condition the master, slave and wheel cylinders are in for the TR3 since it's been off the road since 1976.
Scott
