Hi,
I just purchased a 74 MGB that has been sitting dormant for at least a year. Never mind its hiatus, it needs a lot of work. Left rocker panel and the anterior section of the right rear fender have rust. The paint is old. The entire interior will need reconditioning/replacing. It remains equipped with an air pump and other emissions paraphernalia. The rubber tube leading from the air pump is plugged with a spark plug. No visible fluid in the radiator or brake master. There is oil on the dipstick and it is black and Above the full mark. I don't see water in the oil. Hoses seem a little dry and brittle. You get the picture. The top is okay and the rear window is clear. It has SU carbs!
I put it in gear and pushed the car. The crankshaft pulley did not turn. However it did not seem as thought the motor were seized. There is no battery in the car and I found the ignition switch lying on the floorboard. Ideas about this? I was going to pull the plugs and push again to see if I could note piston movement. Any other thoughts here appreciated. My second question is the gas tank. I haven't seen a plug. If indeed it doesn't have a plug, should I pull it and drain it? Should I clean it? If so, how?
Obviously I've never dealt with a car that has been left sitting. Some guidance would be appreciated, especially with regards to prioritizing.
Thanks,
Bill K in Greensboro, NC
Thanks,
