Wanted Wanted: Tr-3 hood spring assembly
karls59tr
I have several parts for the hood spring assembly. Missing the bottom half of 3/8 rod and two washers. I believe the threaded pin part of the rod may be fabricated by a PO. I think the original pin was one solid piece.
55modified Wanted Wanted rough BN1/2 hood for cutting up Austin Healey Classifieds 0
M TR2/3/3A TR3 engine hood wanted Triumph 7
M TR4/4A Wanted: TR4 Hood [Bonnet] Triumph 6
J Wanted Help Wanted -SE WI Other British Classifieds 0
J Help Wanted - SE WI Racing 0
D Wanted: Austin Healey Classifieds 4
D Wanted: Austin Healey Classifieds 0
35 Siddeley MGB MGB Armstrong shock dimensions wanted MG 0
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
T Wanted Wanted - 1956 TR3 Crankshaft Triumph Classifieds 0
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
Obtong WANTED: TR7 (Olympia/Seattle Area) Triumph Classifieds 0
J Wanted- Late TR4 seats or seat frames Triumph Classifieds 0
Pythias MKIII Springs WANTED Spridgets 8
J Bugeye seats wanted... Spridgets Classified 0
gbtr6 Wanted: '96 LHD Drivers side master window switch panel. Jaguar Classifieds 0
R Wanted 3 main crank MG Classifieds 1
R Wanted 3 main crankshaft MG Classifieds 0
bugedd Wanted: Bugeye cockpit surrounds Spridgets Classified 7
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
B Wanted wing windows gt6 Austin Healey Classifieds 0
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
T Wanted. 14"-16" Vintage wood steering wheels Other British Classifieds 3
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
steveg Healey Billet Pedals Wanted Austin Healey 6
G Wanted - Glove Box Door for a TR3A Triumph Classifieds 2
R wanted TD parts MG Classifieds 0
AngliaGT WANTED - Cheap TD Engine/Transmission MG Classifieds 0
M WANTED......Cannon Inlet Manifold Triumph Classifieds 0
Bayless Wanted: Spridget horn button bracket Spridgets Classified 1
M Wanted TR6 Rear Bumper impact Brackets Triumph Classifieds 0
Kdub Wanted TR6 Mechanic Triumph Classifieds 2
S Wanted Wanted - C39 Dynamo [22258D] Triumph Classifieds 1
S Wanted Wanted - TR3A Horns Triumph Classifieds 2
rr64 Wanted Early MGB Inner Steering Track Rods Wanted MG Classifieds 1
C Wanted WANTED Heater fan motor and housing for 1964 MK3 Sprite Spridgets Classified 2
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
G Wanted Non Overdrive gearbox wanted Austin Healey Classifieds 0
69MGC MGB Wanted: Pair of 67 or earlier Carbs MG 2
69MGC 65 to 67 carbs wanted MG Classifieds 4
CharlesBN1 Wanted wanted to buy - sidescreen trim/strips for early BN1 Austin Healey Classifieds 5
F Wanted Used leather interior for BT wanted Austin Healey Classifieds 5
J Wanted Re: WANTED TO BUY: TRIUMPH TR3 ASH TRAY PULL KNOB Triumph Classifieds 1
AH67 Wanted Wanted steering Idler Box & Arm Austin Healey Classifieds 3
P Wanted WANTED To Buy a TR4 or TR250 Triumph Classifieds 3
steveg Advice wanted on HF impact wrench purchase Austin Healey 12
B Wanted Wanted: Trailer hitch for 1960 TR3-A Triumph Classifieds 7
AH67 Wanted WANTED: Valve cover 6 Cylinder Healey Austin Healey Classifieds 2
AH67 Wanted WANTED: Valve cover 6 Cylinder Healey Austin Healey Classifieds 0
