volunteer
This is a 1971 right-hand drive limo. Master cyl. is at steep angle and is physically 7 inches in length. The mounting flange is 3.25" hole to hole and the fluid inlets on top. Front (closest to booster) inlet is a flange about 1.125" hole to hole. The front seal is approx. .872" dia. with a .435" hole and rear seal is much narrower and has an O.D. of about .832" and inner hole about .50" - - I say approx. or about because seals are still as installed. These parts likely fit other Daimler or Jag master cyls. but I have absolutely no info to search. I will need, at very least, the two above mentioned seals and at the very most, the complete master cyl. Can anyone point me in right direction? Please and thank-you.
