Legal Bill
kozelding said:Healey_Z said:Randy Forbes said:I hit them until they don't move.
Are you talking a back swing of 3 inches, 6 inches, 12 inches, 18 inches, 24 inches, more?
Indeed, aside from marring the ears, my question has always been, has anyone ever seen damage from over-tightening?
It would seem unlikely that you'd strip the threads or distort the wheel. And, given how common worn splines are, I would think erring on too tight rather too loose is safer.
Yes, I have seen damage from over tightening. I've seen the knock on split where the hub pushed through the middle of the spinner.
At some point one must apply a bit of common sense. Follow the directions provided by Dayton. Your swing should be relatively short as aim is just as critical as force. You don't want to be swinging so wild that you can miss and hit your spokes or hand. That said, 3 to 6 inches will not generate any real force. While 18 inches sounds about right, I would need to actually measure my swing to give you a precise measure.
