Vixen 2500 Spindle Dimensions - Original Configuration or No?
Rocky_LC
Due to an issue I found (from a previous owner(s?)) - I had to do a deep dive into my front spindles. The results are interesting, and I wanted to see if I could determine if I have original spindles, and if not, what the source is.
The Problem (Corrected):
I kept losing preload on my front passenger wheel bearing. It turned out the inner bearing race that was installed in (both sides) was undersized, and the PO had installed a brass shim. On the pass side - the shim hadn't perfectly engaged the bearing, and slowly was being crushed, allowing the race to drift slightly towards the upright. On the driver side, the shim was installed "properly" (if you can call it that), and the race was fully seated in the hub.
I know what bearings & races I need - the information below is intended to help identify the source of the spindle.
The Bearing & Spindle Dimensions:
I believe the components of interest in the front of should be (mostly) Triumph TR6. I have a TR6 Hub and Rotor, TR6 Calipers and Pads, and was able to use "some" of the TR6 Bearing components, as listed below:
Inner Bearing: Diameter Source Comment
Race: Timken L44610 1.980" OD ???? Undersized - Shimmed
Race: KOR 07210X 2.000" OD TR6 Correct Size - Fits Hub - Delivered in a Lucas Box Market TR4-TR6
Bearing: Timken L44649 1.062" ID TR6 Correct Size - Fits Spindle - Was on Car from the PO
Bearing: KOR 07100S 1.000" OD ???? Undersized - Doesn't fit spindle - Delivered in a Lucas Box Market TR4-TR6
Outer Bearing: Diameter Source Comment
Race: ??? (Installed) 1.575" OD TR6 Correct Size - Fits Hub - Delivered in a Lucas Box Market TR4-TR6
Bearing: KOR 03062 0.625" ID TR6 Correct Size - Fits Spindle - Delivered in a Lucas Box Market TR4-TR6
Conclusion & Question:
So I am going to use the KOR 07210X Race and Timken L44649 Bearing (after checking with the Folks at Beaver Bearing that they are compatible). But - what car is this spindle from? It's not TR6, and I thought Herald / Spitfire / GT6 were SMALLER than TR6 components.
Any wisdom from this august group?
Thanks -
Rocky
This is what AI tells me, which says the inner wheel bearing is the same for both the Spitfire and the TR6.
Front uprights are a weak point on these cars and something that I would up grade if working the car hard.
These are used on super sevens with success but not so much on TVRs.
Yes, I would agree (based on just looking at it, not from experiencing a failure). But one might say that about the whole front suspension design….
The upgrade route can be a slippery slope!
What did you do on #1?
I left it stock, as it was not going to get heavy work due to its rarity.
Most quality upgrades can be found in the UK from specialist, not “box fillers” that sell junk.
