I have a 70 GT6+ and I noticed that when putting power to the rear end I get a vibration. At 60 the vibration is worse then at 30. It also depends on the gear that I am in. If I am doing 50 in third it is worse then if I am doing 50 in forth. If I let off the gas the vibration goes away. We just put a new clutch in the car and also the car sat for 3 years.
The 4 items I can think of are:
1. It is the drive shaft is out of balance
2. The rubber donuts are going bad in the rear
3. Tires are out of alignment (but wouldn't this still cause the shake with the power off)
4. Did something wrong when putting the drive shaft to the gear box. I marked the fittings before taking it apart and put them back together in the same holes.
What are your guys thoughts on this? What else should I be looking at.
