There is a POR-15 Solvent available, but I'd think you'd have to be careful not to spill it on places you'd want to keep protected.
Not really sure how well it works on fully cured POR-15...
(POR-15 website says: <span style="font-style: italic">Clean up mixing and application equipment immediately after use. Tools should be cleaned after work but before the paint hardens using a urethane thinner. Cleaning is not possible after hardening. Observe all fire and health precautions when handling or storing solvents. Use POR-15 Solvent or POR-Strip for cleanup.)</span>
SO doesn't sound like the solvent would be very effective on a fully cured coat...
Pretty nasty stuff. So you'd have to protect eyes. skin, & use in a well ventilated area.
Probably pretty expensive too (especially in large quantities).
HOPEFULLY the shop that applied the POR-15 did something to thin it out 1st on the outer panels... (MIGHT be easier to remove if a thinner coat was applied)
