Vertical Oil Cooler Lines
GB1
On a vertically mounted oil cooler, should the botom be mounted to the return/filter and top to the pump output or visa versa, the top to the return and bottom to the pump?
Please advise, I believe the first.
Thanks, Patrick
Bugeye58
Patrick, the filter should be on the pump output side. On a vertical mount, I've always run the pressure side to the top.
Jeff
GB1
GB1
Thanks, that how I had her last time, just wanted to make sure, because in the past she too a few seconds to get pressure at the gauge.
Platinum
THAT would have surprised me. I didn't think you had one, but I've been stunned before. /ubbthreads/images/graemlins/jester.gif
billspohn
[ QUOTE ]
[/ QUOTE ]
With pressure to the top, the column of air (if any) will be compressed - I don't think you'll get pressure any faster.
I always do it the other way - oil in at the bottom. That way it is self-purging and the air is forced out the top.
Not that you should have any air in the system, but......
I also run an Accusump.
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
S TR2/3/3A vertical links Triumph 8
banjojambo Triumph tr3 vertical link wobble Triumph 2
V TR2/3/3A Vertical link check Triumph 2
S TR2/3/3A Vertical link Triumph 3
S TR2/3/3A How bad is this? Vertical link Triumph 12
J TR2/3/3A L/S Vertical Link Resistance Triumph 17
S TR2/3/3A tr3 painting --spraying: vertical, horizontal ect... Triumph 8
Scotsman TR4/4A Front Suspension Vertical Link Triumph 2
mcmillal TR4/4A Broken Vertical Link Triumph 17
J TR2/3/3A Need a TR3 vertical link Triumph 1
T TR2/3/3A TR3B vertical link Triumph 13
T Help on ball joint - vertical link fit Triumph 20
A TR2/3/3A TR3 Trunnion - vertical link play Triumph 10
T Vertical link questions Triumph 4
Bremer Help with vertical link assessment Triumph 6
C Distributor shaft vertical play? Triumph 4
tinman58 Vertical Links Triumph 5
B Vertical link question Triumph 1
HEALEYJAG 100 vertical fin from apron panel set Austin Healey 8
M Removing Stub Axle from Vertical link Triumph 22
G trunion/vertical link seal Triumph 5
svtmikey Front Vertical links Triumph 3
WALTER Vertical vs. Cross-flow radiator Spridgets 5
Carlbanan56 MGB MGB oil consumption MG 5
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
R TR6 question re: Engine Oil Triumph 3
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
