Vertical link questions
tdskip
Hi guys - my vertical link (#20) has one of the bolts (#39) stuck in it.
Any issue in using it as-is (with the bolt stuck in it)?
M_Pied_Lourd
Hiya Skip,
If I recall, two are threaded and two are straight through with nylocs. IS it the threaded ones that are stuck?
Cheers,
M. Pied Lourd
TR3driver
Great Pumpkin - R.I.P
#39 should be a slip fit through the caliper bracket, VL, spacer and steering arm; with a Nyloc nut on it. Should be no problem leaving it stuck in the VL, as long as you never want to change the caliper bracket
But I'll bet that if you soak it in PB Blaster for a few weeks, it will come out. Bend back the tab and use a box-end wrench to try to turn it back and forth.
TR4nut
You may be binding on the spacer #20, I bet with PB or a little heat etc you can get it free. On my TR3, I had to remove that caliper bracket, otherwise the link wouldn't unthread off the trunnion - is the 4A setup the same way?
Minesweeper
That's where my bolt was seized -- corrosion between the bolt and spacer. I sprayed it with PB Blaster, then held the spacer with a pipe wrench and hit the bolt with an impact wrench. This un-seized the two and after another 30 seconds of spinning the bolt I was able to extract it and the spacer.
Scott
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
banjojambo Triumph tr3 vertical link wobble Triumph 2
V TR2/3/3A Vertical link check Triumph 2
S TR2/3/3A Vertical link Triumph 3
S TR2/3/3A How bad is this? Vertical link Triumph 12
J TR2/3/3A L/S Vertical Link Resistance Triumph 17
Scotsman TR4/4A Front Suspension Vertical Link Triumph 2
mcmillal TR4/4A Broken Vertical Link Triumph 17
J TR2/3/3A Need a TR3 vertical link Triumph 1
T TR2/3/3A TR3B vertical link Triumph 13
T Help on ball joint - vertical link fit Triumph 20
A TR2/3/3A TR3 Trunnion - vertical link play Triumph 10
Bremer Help with vertical link assessment Triumph 6
B Vertical link question Triumph 1
M Removing Stub Axle from Vertical link Triumph 22
G trunion/vertical link seal Triumph 5
S TR2/3/3A vertical links Triumph 8
S TR2/3/3A tr3 painting --spraying: vertical, horizontal ect... Triumph 8
C Distributor shaft vertical play? Triumph 4
tinman58 Vertical Links Triumph 5
HEALEYJAG 100 vertical fin from apron panel set Austin Healey 8
GB1 Vertical Oil Cooler Lines Racing 6
svtmikey Front Vertical links Triumph 3
WALTER Vertical vs. Cross-flow radiator Spridgets 5
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
Jim_Stevens Off Topic Ethanol-free gas link Triumph 1
D MGB Rear Suspension Damper Link Arm MG 2
BN6_2197 BN6: Shock absorbers do not fit after renewing the link arms Austin Healey 20
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
N Watts Link??? Spridgets 2
H broken sway bar link - again Austin Healey 8
T TR2/3/3A tr3a verticle link removel question Triumph 11
G BJ-7 Rear Shock Link Austin Healey 2
B Support bracket for the rear suspension damper link Austin Healey 5
D TR4/4A stubborn lever shock link Triumph 2
Geo Hahn TR2/3/3A Vent Lid Link Triumph 3
N Top link offset bushings?? Spridgets 6
T TR5/TR250 250 Sway Bar Link Triumph 0
drooartz General MG Alternator link - adjusting bracket length on MGB? MG 8
T Perished Rubber/etc on BE rear shock absrober link Spridgets 0
DornTRoriginal TR2/3/3A Horizontal Link Assembly Install Question Triumph 1
D TR2/3/3A Vent lid link length Triumph 8
J TR4/4A 67 IRS Damper arm/link removal help Triumph 10
mgedit TR2/3/3A Link Rod Lengths Accelerator Linkage Triumph 2
S TR4/4A Reversing upper fulcrum link Triumph 3
B Parts for sale on Panjo link Austin Healey 0
M_Pied_Lourd TR2/3/3A Verticle Link to Trunnion Fitment Triumph 5
K Jaguar 140 Restoration Link? Jaguar 2
