Hello Team!
I have completed a restoration of my passenger side door including new glass seals and brush bar and a rebuild of the window regulator.
I have also attached a rechromed waist moulding, but am looking carefully at the area where the vent window's guide post goes into the door cavity.
There seems to be a 1 inch gap between where the main outer window seal ends and where the vent window surround seal starts. This leaves a 1 inch gap where water could potentially enter the door. The rubber window seal seems to be the proper dimension when aligned to the end of the door.
I was wondering if someone could take a look at the attached image, and let me know if I have done something incorrectly, or should I get out a tube of black silicon?
Thank you,
Andrew
Thank you,
Andrew
