TR2/3/3A Vent lid link length
DickN
One of the parts missing on my project car is the metal link that opens and closes the the vent. I am going to make one, (a straight piece of metal with two holes) but I would like to find out the length if possible.
Thanks,
Dick
M_Pied_Lourd
Hi Dick,
If you are talking about a TR3, it is a thin metal rod. The rod fits through a fitting with a nut on the belcrank that lifts the flap up and down. Not sure of the length though...
You can just see the rod in the right hand side of this photo of the mechanism
Cheers
Tush
M_Pied_Lourd
Got ya. My bad.
So, this is the piece that you are looking for...
I can try and get that for you later tonight.
Cheers
Tush
M_Pied_Lourd
Tough to measure in there, but I broke of a piece of paint stick and fit it in there against the metal link. It is 5 inches in length from rounded end to rounded end.
Cheers
Tush
DickN
Cheers
Tush
Thanks for measuring this!
The length and your photo will make easy to duplicate.
Dick
M_Pied_Lourd
Well, that's what I thought I got....like I said, I put a piece of paint stick in there and held it against the link then took it out and measured it with a metal ruler....
Is your link out of the car? I can double check my measurement tomorrow. Can't believe I am that far off but I have been wrong before. Sorry to Dick if I am....
I wonder if I was reading a metric ruler (5 cm is 2 inches)....didn't think I had a metric ruler in the garage but it is possible..
Cheers
Tush
PowderBlue
Cheers
Tush
LOL. Yes, I have one on the bench.
Geo Hahn TR2/3/3A Vent Lid Link Triumph 3
T TR2/3/3A Vent lid Mechanism Triumph 6
S TR2/3/3A vent lid rubber Triumph 11
B TR2/3/3A Vent cowl lid mounting points Triumph 3
M TR4/4A Vent lid fit......is this acceptable? Triumph 11
M TR4/4A Vent lid rod...help please Triumph 3
M TR4/4A Vent lid operating rod. Triumph 2
T TR2/3/3A TR3 Vent [not the verb] lid pin Triumph 5
I TR6 TR6 Vent lid removal Triumph 6
A vent lid Triumph 2
pa297pass TR4/4A TR4 Cowl Vent Lid Triumph 2
tinman58 TR2/3/3A Vent tube Triumph 3
M 1275 Timing Cover Vent Spridgets 2
B For Sale BaulyCars - Scuttle Vent Cover Triumph Classifieds 0
Bayless How to repair broken vent window studs? Spridgets 1
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
T Early BJ7 Vent Window Seal Austin Healey 2
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
B Roof vent position on BN7 hardtop. Austin Healey 15
C TR2/3/3A scuttle vent Triumph 6
A PLATE, handle locking on Vent Window Austin Healey 0
M TR6 Tr6 fresh air vent replacements Triumph 1
T TR6 Air vent rod connection Triumph 1
P Rivets on windshield and vent window frame. Austin Healey 1
D Austin Healey side rally vent Austin Healey 10
AUSMHLY Hose, vent pipe to air cleaner, BJ8 Austin Healey 7
P Help With Side Vent Glass Removal Austin Healey 7
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
M TR2/3/3A TR3 Valve cover vent oil leak Triumph 8
HighAltitudeTR3 TR2/3/3A Vent Tip... Triumph 16
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
T TR2/3/3A Is this overdrive vent sufficient? Triumph 3
B BJ8 vent window collar fused on Austin Healey 7
N TR2/3/3A TR3 Scuttle Vent Triumph 15
N TR3 scuttle vent FORUM Navigation Questions 1
S TR2/3/3A Smoke coming out of crankcase vent? Triumph 21
Rut TR4/4A Defrost vent finish Triumph 3
T TR2/3/3A Rear Axle Vent Triumph 12
D TR2/3/3A TR3 Scuttle Vent knob removal? Triumph 2
K TR2/3/3A The "air vent"on the lower part of the front apron below the grille.... Triumph 5
K TR3A Air vent under grille on Race Cars? Racing 5
T Post-War Other The Herald front vent windows Triumph 5
T Post-War Other The Herald front vent woindows Triumph 0
J BJ8 Float bowl vent pipes Austin Healey 11
M TR2/3/3A Air Vent Drain Hose Triumph 5
P TR6 Air vent hose clamp Triumph 0
S Question: Works Vent, how to fit Austin Healey 0
P Rocker Cover Vent Spridgets 22
D footwell vent Jaguar 3
