TR4/4A Vent lid fit......is this acceptable?
malbaby
In the process of fitting the vent.
Have not fitted the internal spring as yet....replacement new rubber seal is fitted.
I am concerned that the lid is not going to close flat, and will protrude above the panel.
The spring will bring the lid down slightly.
Was this the case ex factory?
trrdster2000
You have cause for concern as something does look off. Is the seal completely down? The springs do have some good pressure and may solve your problem. Hope so.
Wayne
Geo Hahn
I recall (but not actually experienced this) prior threads where a replacement seal was either too thick or too stiff to allow full closure. The solution for some was possibly trimming the seal - but a search may turn up the full story.
tdskip
+1
TRMark
Bronze
I replaced the seal on my car several years ago, fits the same, not very well.
JerryVV
There were some seals on e-bay a while back that worked fine, they were thinner, i used one with success.
Jvv
Gordon_Dedrick
Put something on the body to protect the paint and then put some weight on top to compress the seal. A couple of bricks will do. The seal on my TR# was not quite as high as yours, but once I did this it looked much better.....and has stayed that way.
T TR2/3/3A Vent lid Mechanism Triumph 6
S TR2/3/3A vent lid rubber Triumph 11
Geo Hahn TR2/3/3A Vent Lid Link Triumph 3
D TR2/3/3A Vent lid link length Triumph 8
B TR2/3/3A Vent cowl lid mounting points Triumph 3
M TR4/4A Vent lid rod...help please Triumph 3
M TR4/4A Vent lid operating rod. Triumph 2
T TR2/3/3A TR3 Vent [not the verb] lid pin Triumph 5
I TR6 TR6 Vent lid removal Triumph 6
A vent lid Triumph 2
pa297pass TR4/4A TR4 Cowl Vent Lid Triumph 2
tinman58 TR2/3/3A Vent tube Triumph 3
M 1275 Timing Cover Vent Spridgets 2
B For Sale BaulyCars - Scuttle Vent Cover Triumph Classifieds 0
Bayless How to repair broken vent window studs? Spridgets 1
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
T Early BJ7 Vent Window Seal Austin Healey 2
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
B Roof vent position on BN7 hardtop. Austin Healey 15
C TR2/3/3A scuttle vent Triumph 6
A PLATE, handle locking on Vent Window Austin Healey 0
M TR6 Tr6 fresh air vent replacements Triumph 1
T TR6 Air vent rod connection Triumph 1
P Rivets on windshield and vent window frame. Austin Healey 1
D Austin Healey side rally vent Austin Healey 10
AUSMHLY Hose, vent pipe to air cleaner, BJ8 Austin Healey 7
P Help With Side Vent Glass Removal Austin Healey 7
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
M TR2/3/3A TR3 Valve cover vent oil leak Triumph 8
HighAltitudeTR3 TR2/3/3A Vent Tip... Triumph 16
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
T TR2/3/3A Is this overdrive vent sufficient? Triumph 3
B BJ8 vent window collar fused on Austin Healey 7
N TR2/3/3A TR3 Scuttle Vent Triumph 15
N TR3 scuttle vent FORUM Navigation Questions 1
S TR2/3/3A Smoke coming out of crankcase vent? Triumph 21
Rut TR4/4A Defrost vent finish Triumph 3
T TR2/3/3A Rear Axle Vent Triumph 12
D TR2/3/3A TR3 Scuttle Vent knob removal? Triumph 2
K TR2/3/3A The "air vent"on the lower part of the front apron below the grille.... Triumph 5
K TR3A Air vent under grille on Race Cars? Racing 5
T Post-War Other The Herald front vent windows Triumph 5
T Post-War Other The Herald front vent woindows Triumph 0
J BJ8 Float bowl vent pipes Austin Healey 11
M TR2/3/3A Air Vent Drain Hose Triumph 5
P TR6 Air vent hose clamp Triumph 0
S Question: Works Vent, how to fit Austin Healey 0
P Rocker Cover Vent Spridgets 22
D footwell vent Jaguar 3
