When posting a classified ad, you MUST select a prefix from the drop-down next to the subject line. If you don't you will get an error and your ad will not be posted!
Directions for the alloy cover indicates you can adhere either side. One side of my gasket is dull red and flat, the other is shiny smooth and looks SLIGHTLY concave? Does it make a difference?
Gordon
You sure you have the right one because it says here:
"The cross-section of this gasket is rectangular to suit the sealing surface of the alloy valve cover. "
Gordon, that's a perfect description of the one I just got for the stock valve cover on my Herald. If it's any indication, the "shiny and slightly concave" side it the side that goes to the head. (With a stock valve cover, the other side is the rounded side, theoretically to better conform to the valve cover. I hope they're right about that and about how well the other side seals to the head!)
