G
I bought a windshield a while back that was too small. You could stick a pencil through the lower corner of the frame with the winshield installed and the frame tightened down. Next, I had a new wheel cylinder only last a few thousand miles before it started leaking. Just got some rear engine mounts in, both are different and one the top studs just popped off (which I can't return as it's "been installed".) I took the 30 year old ones out of the garbage and put them back on.
Included in this order was a cam gear with no timing marks and last but not least....a timing chain WITH A MASTER LINK !!!!
I can remember being taught as a toddler by my father, that <span style="font-size: 12pt">TIMING CHAINS DON'T COME WITH MASTERLINKS FOR A REASON !!!</span>
I've installed a few dozen chains in my life, and I have sold probably hundreds, if not thousands of these things and NEVER ONCE, have I seen a timing chain WITH A MASTER LINK! Apparently, they are buying bulk chain and cutting to fit.
(Costs about $2.)
What really bothers me about this, is the proper mounting instructions for a linked chain aren't included and you won't find it in the manual because.....TIMING CHAINS AREN"T SUPPOSED TO COME WITH MASTER LINKS !!!
I feel for the unsuspecting soul that doesn't know any better and puts it in backwards.
Apparently, VB has suspended the laws of physics and they don't apply anymore. I'll be sure and notify Dad.
Is Moss any better, worth the extra $$$?
MAN this makes me so mad.....
(Costs about $2.)
Hi Guest!
