Well, I'm at the point of working the bugs out mechanically. After sitting for a few days, I have a problem with vapor lock. The problem apparently is between the fuel pump and the in line filter I installed about 8-10 inches upstream from the pump. The symptoms are no start, fuel pump running continuously. Remedy is to loosen the line between the pump and the filter, then run the pump till gas runs out. After re-tightening, everything runs just fine. Whassup?
