bigjones
Another attempt at the vapor lock problem in the 1500 Midget:
I've got some heat sheath for the fuel lines. If nothing else, it will look better that the existing plumbers foam pipe stuff.
Also, got some insulating tape that I plan on putting on the back of the carb heat shield, around the carb fuel bowl (HS4 carb) and also around the mechanical fuel pump. I was going to insulate the back-up, under-the-hood, electric fuel pump but have read that, because it generates it's own heat, it would only serve to cook it even more.
While I'm at it, I was also thinking of making a heat shield for the mechanical fuel pump. If so, to maintain the same distance from the engine block, I was going to dispense with the gasket and just use some Ultra Black .
Comments welcome before I get cracking!
Cheers!
Cheers!
