TomChar
If you drive it at all in winter temps, I wouldn't have any straight weight in there, it could be too thick at startup. Otherwise, blending oil is fine, you just have to remember what the numbers mean. The second number (without the "W") is the normal operating temperature rating (all grades measured with the oil at 210F), while the "W" is the Winter or cold temperature rating, and tested at different cold temps. So if the second number is the same, than the oil is the same once warmed up. For summer driving, when normal folks drive their cars, using a straight grade oil is perfectly acceptable, just give it a little warm up time. If you're like me and go out in 20F weather, you'll need a multi-grade to protect those bearings when first started. The winter ratings are measured at various temps, all below freezing. 20W is measured at -10C (14F), while 10W is at -20C (4F). Yeah, don't ask me how that works.
