Valve Timing Theory
I have a couple of questions on timing theory. Hope someone can set me straight. I do not need to know how to time them, there are lots of threads on that. I would like to discuss valve events and the results of (mis-timing)moving the timing one way or the other.
Lets suppose i have a kent cam (th2), the intake timing at full lift is 108° ATDC.
what would the effects to performance and the engine be if say it was set at about 90° ATDC? Obviously performance would be lost- but what other effects would be seen? such as would it run rich- or lean? would it run at all? Would ignition timing have to be advanced to compensate? Other thoughts?
mark
You need to talk to Charlie Tolman In Mpls. You can find him at sprite spot He can tell you all you need to know about cams and timming.
My Desktop Dyno says HP/Tq would go from about 80/87 to 67/71. That's a 15% loss in power. Granted, this is just a computer program and obviously it can't say anything about rich/lean, timing or runability. The program always "assumes" ideal A/F ratio and ideal ignition timing.
I can say from my personal experience however that when you install a timing chain set and you get off by ONE TOOTH, the car is still driveable, even some pep, but none of the dig-down-deep, get-up-and-go. I drove my car for months with the timing off by one tooth. I want to say that I had to really richen up the mixture to compensate. I never changed the timing however.
JACK
The PO had my Opel's 2,0 cam off by one tooth too (or it slipped). I managed to massage it back to good. Hard to tune that way.
