Valve stem seals or double springs?
billspit
I got a call from the head shop yesterday asking me if I wanted to install seals on the valve guides. I know Spitfires do not use them as standard and I was planning on using the double European spring set I got. If you use double springs, no seal will fit. What is the opinion of you guys? Use the seals and drop in the inner spring? Or stay with the double springs? This car won't likely get a lot of mileage since my Mk I hasn't. I felt the valve actually needed and little lube on them for longevity.
Also, with all of the trouble with cams and lifters these days, I've seen a lot posted that you should only use one valve spring until the engine is broken in. Then install the inner spring. This is mainly for high performance engines and mine is only a slightly breathed on 1500. Do you think it is necessary to leave the inner spring off at first?? I really don't want to try and do this on the engine later by myself.
Opa
Bill if it were mine I would put it together with new valves and guides reamed to spec. put in the double springs and go.I personally don't like seals on an engine designed to run without them, however if your putting a head together reusing old valves, guides,then I would look at clearences closely and possibly use seals.
I'm not convinced that hd valve springs are the problem as much as inferior lifters and possibly cams.
If possible I would have lifters checked for rockwell hardness. I have used BPNW lifters on several engine jobs and had them checked for hardness on my own motor and found them to be well within spec.usually at 56- 60 rockwell.Haven't had any cam troubles yet. JMO
Tosh
Billspit,
I installed the double springs on my recent head rebuild. There were two reasons;
1.) The cause for the rebuild was a broken spring which caused a dropped valve (into the cylinder). I figured that the inner spring would help to insure that a future broken spring would not release the keeper and allow the valve to drop.
2.) The advisor at British Parts Northwest said that the increased spring pressure was negligible.
Keep on
B
billspit
Thanks for the feedback. They have finished the head with double springs. No seals used. BTW, I had brand new valves and guides installed.
Flinkly
so i have a rebuilt head with old valves and new iron guides. should i have my seals removed? they put them there when they built it up, without asking. i should probably at least ask why.
Brosky
I went with seals this time, in the event that I decide to install an oiler again. It may never happen, but if I do, I'm covered this time.
CharlesBN1 Uprated or 'umbrella' valve stem oil seals for BN1 Austin Healey 2
L Valve stem seals? Guides? Or???? Spridgets 17
kyreb1862 MGB Valve Stem Seals 77 MGB MG 2
J Viton valve stem oil seals Triumph 3
Sarastro 1275 valve stem seals Spridgets 6
heliguy Valve Stem Oil Seals Triumph 7
E Valve stem seals British Motor Corp 3
S TR2/3/3A tr3 valve spring compressor Triumph 2
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
KVH General Tech Heater control valve/cable Triumph 1
G Valve Train Lubrication Austin Healey 1
KVH General Tech Valve Timing--No Marks Triumph 20
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
D Water Valve Connection Austin Healey 4
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
RJS General TR Lever Shock - HD Shock Valve Triumph 2
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
M TR5/TR250 Bypass valve Triumph 27
I Bugeye valve rebuild suggestions Spridgets 8
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
J Oil Pressure Relief Valve Austin Healey 3
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
K TR2/3/3A Camshafts and Valve Settings Conundrum? Triumph 7
charlie74 TR6 ‘74 valve springs Triumph 0
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
M TR6 PDWA valve Triumph 6
M Ray Juncal Valve Covers Austin Healey 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
K TR2/3/3A Brake Restrictor valve? Triumph 9
Lin Heater water valve question Spridgets 2
D MGB MBG valve clearance MG 1
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
A T-Series MGTD oil pump bypass valve MG 0
S Price check on TR3A valve cover Triumph Classifieds 0
