Thinking about replacing the worn rocker shaft. Looks like a very small pin holds the end collar on. How difficult is it to drift out that pin seeing as how the collars are N/A I don't want to bugger them up?
Also I noticed that the lock nuts on top of the pedestals look like they are gouging into the pedestal tops? Is this why they went to flat washers for the TR4 heads? Would it do any harm to use flat washers below the lock nuts or does that throw out the spec somehow?
