TR2/3/3A Valve Material
CJD
Next offbeat question.
I was browsing the service manual and noticed the material for the original exhaust valves was a "chrome nickel steel stamping with a stellite tip". The current valves available are listed as stainless. Does anyone know how well stainless compares to the original material? Is the stellite tip significant enough to be worth 4 times the cost of a straight stainless tip?
vivdownunder
Depends how much use the car will get. Stellite tips are as hard as billy goat's knees as to defeating flat tappet scuff wear. Softer stainless steel valves, especially exhaust valves, only rate about 40% of the life of stellite valves.
Viv
CJD
CJD
Thanks, Viv. It will see little use. I was just worried, as I recieved 3 heads in my Christmas pile, plus the 2 I have been working on for the TR2...and on every head one or two valves are mushroomed out on the tip. I have used straight stainless on many other engines, even with pretty heavy valve springs, and have had negligible valve tip wear problems. I just wondered if the triumphs are harder on tips?
TR3driver
Great Pumpkin - R.I.P
Not likely the factory used Stellite unless they perceived a problem.
TR3driver
So, Randall, I guess you are recommending the stellites?
I basically agree with Viv; probably not necessary for an engine that won't see long, hard usage. I'm pretty sure the oversize valves I got from BFE were just stainless, and the tips still looked OK after 10K miles or so. (Wish I could say the same for the hardened exhaust seats)
TriumphantMan
What kind of trouble did you have with the hardened valve seats. I'm rebuilding my '63 TR4 and maybe I can avoid any trouble.
What would you have done different?
TR3driver
I don't really know what the problem was; but I think my mistake was using "racing" valve springs and not checking the seat pressure. Or it might have been the too-high compression ratio and not removing the sharp edges in the combustion chamber. Or even the MMT-based octane improver I used to compensate for the high compression ratio and tendency to knock. Another possibility is that the altered combustion chamber shape (from milling the head) was enough to move the mixture lean during high rpm medium throttle operation.
At any rate, those are all things that I will do differently next time. I probably should have tried running lead substitute to see if that would stop the recession, but I didn't. (I was kind of distracted with other things at the time and driving the TR was a sort of therapy to keep me going.)
Here's a shot of the modified head, after perhaps 20k miles of mostly street driving:
As you can see, the exhaust valve has extreme recession. It was so bad that I could no longer adjust the valve lash, even with shims under the rocker pedestals and shorter pushrods. The spring retainer was literally hitting against the rocker arm! Less obvious, the intake valve seat (which is still the original cast seat) has recessed a bit as well. At the time, I just threw the modified head in the corner (where it still resides) and installed an unmodified head from another motor (no other changes). It was still running fine (though not nearly as much torque & power as the high compression produced) a few years later when the car got totaled in an accident.
71tr PDWA Valve O-Ring Material Triumph 6
S TR2/3/3A tr3 valve spring compressor Triumph 5
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
KVH General Tech Heater control valve/cable Triumph 1
G Valve Train Lubrication Austin Healey 1
KVH General Tech Valve Timing--No Marks Triumph 20
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
D Water Valve Connection Austin Healey 4
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
RJS General TR Lever Shock - HD Shock Valve Triumph 2
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
M TR5/TR250 Bypass valve Triumph 27
I Bugeye valve rebuild suggestions Spridgets 8
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
J Oil Pressure Relief Valve Austin Healey 3
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
K TR2/3/3A Camshafts and Valve Settings Conundrum? Triumph 7
charlie74 TR6 ‘74 valve springs Triumph 0
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
M TR6 PDWA valve Triumph 6
M Ray Juncal Valve Covers Austin Healey 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
K TR2/3/3A Brake Restrictor valve? Triumph 9
Lin Heater water valve question Spridgets 2
D MGB MBG valve clearance MG 1
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
A T-Series MGTD oil pump bypass valve MG 0
S Price check on TR3A valve cover Triumph Classifieds 0
H BJ8 Heater Valve/Control Tap Austin Healey 3
J Wanted ZS 175 CD-2 Air Valve Triumph Classifieds 0
G Valve adjustment and easiest way set cam position Austin Healey 15
CharlesBN1 Uprated or 'umbrella' valve stem oil seals for BN1 Austin Healey 2
dbenichou289 TR2/3/3A Valve seats Triumph 8
steveg TR6 Adding a PCV valve Triumph 5
