VALVE ADJUSTMENT
BOBBYR
Hello Guys,
I hope everyone is doing well. Last year,I adjusted the valves on my 65 3000. I thought it would be best to set them at .012 as is marked on the valve cover. This spring I'm setting them at .015. I was wondering what you all think. Do you think it will run smoother at idle and maybe event get more power on acceleration? As always,I appreciate your help.
Bobby R
If you're setting them with the engine stone cold, use .015" otherwise, use the spec for the camshaft: .012" (hot) for the OE cam.
My Isky T-3-6 cam requires .018" (I) & .020" (E).
