RickB
I got back into town tonight and of course went right to my car. Had to drive out to get a can of starter fluid.
Spraying (while car running) at shafts, intake manifold, gaskets, all over - no difference whatsoever.
Thought I'd try with the timing, retarded it to where it was idling good about 900. Of course it wouldn't really drive like that.
Put timing back - yes I had noted the starting point - and tried again, running better but higher rpm again.
Adjusted carbs again, started all the way in and turned out until carb performed correctly with the "lift the pin" method.
Then did the other. Low and behold the idle is only about 1100 rpm. Way better than 2000 rpm.
I'll try driving it tomorrow like this and see what I think of it.
Considering this is a Japanese 1500 with a performance 1400 head and a set of British SU carbs - I think I'm doing OK.
Hi Guest!
