I second that, I wouldn't lock your mechanical advance. However, if you tune your car to run well, you can adjust timing slightly to compensate for the lack of vacuum advance if you so desire. Since optimum advance is hard to determine, it's difficult to recommend a particular timing figure. Also, you'll probably never notice a difference in driving of the car if the carbs are properly tuned and the spark is set as per factory settings. My car runs about 34 degrees total advance, which amounts to a heck of a lot at idle, but it runs pretty much fine at as much as 38 degrees advanced (except for a slightly over-advanced idle due to the limited range of mechanical advance in my distributor, about 24 degrees). My recommendation is to follow the factory spec unless you have a hotter engine. Vacuum advance won't make a whole lot of difference, but it might improve the gas mileage slightly. And, as mentioned before, if you lean it out a bit (the way the manufacturer intended), the advance makes it run better (but not as well as if the carbs are tuned properly).
