Vacuum reading access
Nelson
With the season of minimal, if any, driving I'm thinking of possible projects. With some of the challenges I've had with setting my engine up there were times that getting a vacuum reading would have been informative. I'm wondering if it would be worthwhile to drill and tap a hole in the intake manifold. It would be plugged for normal use and provide a measurement point when needed. I assume that I would make the location in the center although I'm guessing that the vacuum should be the same everywhere inside it. Would this be a worth while modification?
I like vacuum gauges so I am biased and say "yes".
The vacuum reading will bounce around a bit so I suggest tapping in the middle of the balance tube between the carbs. I have modified one of my Triumphs just like you are proposing. I tapped a 10-32 hole in the middle of the tube and installed a small barbed fitting. When the connection is not in use I put a small vinyl cap over the barbs.
I agree but Nelson be wary of drilling into too thin of metal on your manifold- it is a pretty rare one and would be a shame to mess up!
BillM
