G
Hello Folks,
On my TCF-series TR3B, I have to install a vacuum pipe assembly from the spark advance to the intake manifold.
Standard-Triumph never heard of the assembly, so neither does The Roadster Factory. I was able to find FOUR vacuum pipes at Moss, with TWO adapters that fit into the intake manifold under the front carb. There are two adapters, one for the TR2 and one for the TR3. I ordered a pipe and the TR3 adapter.
Well, the threads on the adapter are wrong on BOTH ends; i.e., they do not fit the manifold and do not fit the female fitting on the pipe. So, I will return the TR3 adapter and try the TR2 adapter. I am not too optimistic.
So, here is my question to you. If the TR2 adapter will also not fit, SHOULD I RETURN THE ADAPTER <span style="font-weight: bold">AND</span> THE PIPE, OR KEEP THE PIPE BECAUSE ONE OF YOU KNOWS OF A WAY TO ADAPT THE PIPE TO THE MANIFOLD?
I am desperate enough on this that I have contacted the previous owner, to see if he, by ANY chance, kept the adapter that he took out of the manifold when he removed the vacuum pipe assembly.
Your expert advice is appreciated,
George
George
