Matthew E. Herd
As I've said ten million times (ok, maybe not that many) I have twin sidedraft webers and problems (what a surprise). As I suspect that there are vacuum leaks between carb and manifold, what sort of symptoms would I see in such a case?
As an aside, when I turn the mixture adjustment screws, nothing really seems to change, at least not significantly. The idle speed barely, if at all, picks up. However, the stumble, which was something of a nuisance, has been removed by richening the carbs a bit. The troubling fact is that though this problem is cured, the idle speed does not change measurably. Should this be the case, or should the idle change noticeably with only small turns of the screws?
