PatGalvin
Hey all
In tuning my British Mistress, I am having some trouble keeping the idle dialed in. My goal is about 900 rpm, but it seems to just move around between 800 and around 1100 rpm, depending on her mood.
I have a semistock engine with a mild road cam (BPNW). Compression is increased from stock by using 87.5mm pistons/sleeves. Dizzy by Jeff at Advanced, with Pertronix. Last checked, compression was around 165 plus or minus 5 psi per cylinder. Engine has less than 1,000 miles on it. Carbs rebuilt by Paltech a few years ago. Valves set at appropriate clearances. Timing per Advanced Distributor's recc's. I've been worried about a vacuum leak on the distributor vacuum advance tube (as possible cause for erratic idle). Is there any way to either check or diagnose a vacuum leak on this line? Or do you guys have other tuning suggestions?
Thanks. She is running very strong, I think. And sounds great. This idle thing is bugging me.
And, of course, when my Spal fan kicks on, the idle drops a couple hundred RPM, due to alternator load. But that's for another thread.....
Pat
Pat
