Vacuum for brake booster
billca
For testing, I want to operate the E-type power brake booster without the engine running to provide vacuum. Is it practical to generate the vacuum with a shop vacuum cleaner or similar gadget?
Bill C.
Hello Bill,
a vacuum (so called) cleaner will not work as it is just a centrifugal fan and does not actually create a vacuum. Air conditioning maintenance people use vacuum pumps, if you could borrow one, but I think the easiest would be to connect to another vehicles engine while it is running.
Alec
Bill:
I was able to test mine with a hand vacuum pump that is available in auto parts stores. But it takes a lot of pumping to even begin to evacuate one of these boosters. It is good exercise though!
I could see that the booster held vacuum well and did move the plunger rod which was all I wanted to know. When I installed it later in the car it worked very well.
