Nelson
I finally got my new brake lines in place and free from the leaks that plagued me before. The tubing I initially bought was evidently too hard to allow forming a proper bubble. Now it is time to bleed the lines. I just bought a Mityvac to help me do the bleeding. In years gone by I used to do the bleeding with a partner pumping the brake pedal. The bleeding was done with the sequence being to start at the farthest wheel from the m/c and working toward the closest. The instructions for the Mityvac state to start with the wheel closest to the m/c. Should I use their recommended sequence since I will be working with a vacuum rather than pressure or should I use the traditional farthest to closest sequence?
Nelson
Nelson
Hi Guest!
