Yeah, vacuum advance - a mysterious topic.
This 1500 has a Pertronix ignition and I replaced the ZS with a single carb meant for an MGB. Other than that it is stock.
OK, so I'm trying to tune it up. I'm, following Barney Gaylord's article:
<https://mgaguru.com/mgtech/care/cf120.htm>
With the vac adv line plugged with a golf tee, I set the timing so that it is about 20 deg advanced at idle. It goes to about 34 deg when I apply max throttle.
So far so good.
However, when I re-connect the vac advance it goes to about 44 deg with max throttle. This is bad because Barney says there will be some advance but it will go away with max throttle.
Now then, the ZS had a port on the carb for the vac adv. The MGB carb doesn't, so I hooked up the vac line to a port (approx 1/8" pipe) on the intake manifold (the one that originally was hooked up to the anti-run solenoid). Didn't I read anyways that manifold vacuum is preferred over carb vacuum?
I was just going to leave the dang thing plugged but I thought I'd ask you guys.
Cheers!
So far so good.
Cheers!
