Nelson
I recently had my distributor redone by Jeff and I'm ready to install it. He said to set the timing to 10 to 14 degrees BTDC at idle. I just bought a new timing light to use for the setting up but I am not sure how to procede. With my 948 engine's timing marks being at the bottom of the engine and the dizzy on top how can I move the dizzy and see the timing marks at the same time? The only way that I can think of is to move the dizzy a little and then lay down to see the marks and repeat the process until the timing is correct. Is there an easier way to do this?
