When adjusting my floats I’m having an issue on the front, leading carburetor. I installed a new seat and Viton tipped needle. I set the gap to lid at about 3/16. I filled the bowls using the manual pump lever. I had fuel running out of the jet into the intake manifold. Clearly not right. I’ve tried two even larger gaps, 1/4 and 5/16. Same thing. The level in the jet is too high, spilling from the top. I checked by removing that piston of course.
I’ve checked the needle and seat out of the car. It closes and seals properly.
Is the problem likely that I’m using the manual lever to refill the bowls? Does the manual lever push too much pressure into the line and cause a bypass of the needle?
PS. I have HS6 carburetors on my vehicle.
