Hap Waldrop
This is topic that has came up here from time to time, so since I was doing this today, I thought I would share what I'm working on today. I'm in my final stages of completing a rebuild on a stock 1098cc 12G295 A series cylinder head to be used on a 948cc engine with a Judson Supercharger running 5 pounds of boost. Ok with that being said, all I really want to do is get the head's combustion chamber volume back to what it would have been with the popular repalcement pistons with a normal 948 cylinder head on the engine, say about 8.3 to 1 compression ratio. Now the 12G295 is listed in Vizard's book to be about 28.5 CCs, but I came up with a bit more than that in what appears to be virgin deck on this head, I came up with 29.5, now I really don't care what is is now, but rather what I need it to be to get me to the 8.3 to 1. Now the original 948 heads, the 2A 628 and 2A 629, and the 12G202 all were around 24.5 to 26 cc range. Now to do this right I had to have the customer feed me his piston dish volume and his deck height. Now never assume, even if you know your engine is stock and factory original that these numbers will be text book, the factory is famous for rather large tolerences, so in the case of this engine with factory "never shaved" block deck and .040" pistons had a deck height of .012, with the given piston dish volume , the bore, the stroke , the compressed head gasket thickness, and the head gasket bore, I can use a compression ratio caculator to help me fiquire out what combustion chammber volume I need, I just keep plugging in lesser cc volumes to I see the number I want to get to my desried CR. Now there are many methods of how to determine once you know your deisred combustion chamber volume, how to know how much to cut off the head itself. While the head is still leveled on the head stands after buretting the orginal volume, I just set the burette up to put the volume of liquid into the combustion chamber that I need it to be when cut. Then I use my depth micrometor and skim the surface of the combustion chamber until I just see it touch the surface of the liquid in the combustion chamber, re-check a few times to make sure I'm right and there ya go, I know now how much has to be removed from the head to get to my desired CR, in the case of this head it was .055", with this head on a 948 engine with carbs and no forced induction and say wanting a CR of 9.0 to 1 it could be more like .080" or more.
Anyway, thought some of you gearheads might enjoy a day in my life.
