bigjones
Hi folks,
Look what happened to the bolt from the ball joint splinter. Ha!
It's the bolt on the bottom. Then I used an unmarked bolt (colored like a grade 8). That broke as well. Then an old grade 5 - even that bent a little until that pesky ball joint popped. (That's not the original long bolt either - that stripped out when I done the tie rods)
Here's the replacement ball joint from BPNW. As you can see, it uses a nyloc nut instead of a castle nut. It does not include a washer. Should I go ahead and use the old one (shown in first pic)? Haynes does not have a torque for the nut. Really, really tight, eh, with blue loctite?
Cheers,
Adrian
TS 58324
Cheers,
Adrian
TS 58324
