jcw67spitfire
OK, I've had to educate myself. Looking at http://knowhow.napaonline.com/what-is-a-agm-battery/ I'm seeing that both flooded, or wet cell, batteries and AGM batteries have lead plates and the water/sulfuric acid solution, with AGM batteries having more plates packed in the same space and "added spongy glass" mats separating the plates. NAPA says AGM's can be more expensive and they last longer. Keep in mind that wet cell batteries can safely be discharged up to 80 percent with out effecting their lifespan. For AGM batteries you don't want to discharge them more than 50 percent, and you want to be extra careful not to overcharge them. I've always had wet cell batteries. I was barely able to fit a DieHard Silver with 600 cold cranking amps in the battery spot for the Spitfire MK2, probably overkill for the mild climate of Augusta.
Thanks. Good to know some real world experience and thoughts. Didn't know until you posted, that wet cells had a much more flexible "discharge" percentage than the AGMs. Come to think of it, what's the advantage of AGM anyway? And why aren't we using something like lithium ion for ICE car batteries?
I think I'll stick with standard lead/acid for my 1957 Morris.
AGM batteries might be a bit of overkill for an older British car unless you've added some fancy electronics to the older car (like GPS navigation, upgraded stereo, etc. That said, I do know AGMs are supposed to last longer ( 7-8 years vs 3-5 for lead acid) and of course they don't require topping up and are thus maintenance free so might be worth trying if you're not concerned about period originality. Interested to hear if anyone has used them in their LBC.
Good - stand by as I'm making short video to go through the settings for Group Notifications.I got the email alert!
AGM as used in my 2011 Land Rover and 2011 MINI Countryman S are decent batteries, but when dead have to be chatrged in a special way and monitored for 30 minutes for heat. Takes a second battery or special charger. Not any lighter than lead acid but lighter than Optima. Found that out when I tried an Optima in my track car. Went to replace and AGM was lighter. I keep maintainer on my batteries. Will I use AGM in my LBC no, but have tube vented batteries to keep the acidic vapor away from the steel bodies.
