PeterK
Re: Update to Bolt On 72 amp Alternator for TR6
I agree. I fit a 63 amp Delco unit on my TR3a and, instead of running the charge through the 30amp gauge, I ran the output directly to my battery + terminal/starter solenoid hot. I used 8 gauge wire. So none of the dash, etc. gets the full amps of the alternator. I have a volt gauge for my 4a with the same setup.
Also agree re:relays for add-ons to your system. Relays isolate the fragile switches from increased amps required for the uprated lights, stereo amplifier, electric fan. Also give you full power to the devices, reducing voltage loss.
So bolt-on isn't totally bolt-on, you also have to do the wire from the alt to the batt.
