blacksummerrain
I've noticed on the underside of the hood on the TR6 I'm working on, the right-side, fore-to-aft, narrow, metal support brace (there are two of them and are to either side of the middle (front to back) of the hood)has popped free of the bottom of the hood sheet metal and hangs down a bit.
My first thought was that a spot-weld or two might have broken free. However, when looking at the one on the left that is still in tact, there doesn't appear to be any location where the support/brace comes into contact with the hood sheet metal. Rather, there appears to be some sort of sealant or gasket running the length of this support about a sixteenth of an inch thick.
Is this brace,in fact spot welded to the hood sheet metal or is it attached by some sort of adhesive. Again, some broken spot welds seem to be the most likely answer but I can't find the locations where these welds once were.
Any ideas?
Thanks, Scott
Any ideas?
Thanks, Scott
