kcbugeye1275
I've been told you can remove undercoating if you can lay pellets of dry ice on it and cover with a blanket, that it will pop off. Anybody tried it?
tosoutherncars said:Is your undercoating wax-based or rubber-based? I have found a sharp chisel to be the best solution for a complete stripdown, accompanied by a heat gun in the case of rubberized undercoat. Followed, in either case, by a wire rotary brush.
