wkilleffer
Hello,
While attempting to cure a lighting problem on my 1974 MGB, I found a grounding point under the hood close to the fuse box. It has two wires leading into it, and one is thicker than the other. It looked like it could be the source of a bad ground, so I relocated it to another screw closeby after cleaning the area to bare metal.
Does anyone know which circuits are grounding there? The reason I'm asking is because my headlights have quit working. All the other lights come on when I flip the switch. I tried jumping the headlight wire to the brown wire at the switch, and nothing happened.
The strange thing is that after moving those ground wires, my right turnsignal doesn't flash.
Headlight trouble seems to dog me no matter what I do, and it's almost as though my memory of how it was cured last time flies out the window.
Are the MGB wiring diagrams that were in the true wiring colors still up on the web somewhere?
Any advice and suggestions would be appreciated.
Hi Guest!
